Hi Josh,
About my environment:
- OS: Windows Server 2016 Datacenter
- Milestone Version: Essential+ 2020 R3
- MIPS is installed
- No Firewall blocking any traffic from my workstation
- All Milestone’s services are running under the administrator account
If there is no limitation from BatAction or Milestone, I am speechless then.
Note I can run any PowerShell scripts outside Milestone with no issue whatsoever.
I’ve added ‘Network service’ account to administrator group (just in case). All Milestone services are running under the administrator account. All milestone’s folders have proper permission to the admin account by default and I rechecked them.
There is no Constrained Language in my PowerShell settings. Here is the result from my PowerShell windows.
PS C:\> $ExecutionContext.SessionState.LanguageMode
FullLanguage
Here is a simple example. Milestone will trigger the PS script in which it will only output content to file. It’ll skip launching chrome and python script and it throws no error after completion.
# Set the location of the log directory
$workingDir = Join-Path $env:ProgramData 'Milestone\BatAction\'
# Create a directory
$null = New-Item -Path $workingDir -ItemType Directory -Force
# Set the location of BatAction log
$transactionLogPath = Join-Path $workingDir 'BatAction.log'
# Define timestamp function
function Get-Time {Get-Date -Format "MM-dd-yyyy HH:mm:ss -"}
try{
# Example 1
Start-Process -FilePath 'C:\Program Files (x86)\Google\Chrome\Application\chrome.exe'
# Example 2
python 'C:\Users\Administrator\Desktop\Hello.py'
# Write to log
"$(Get-Time) Output Deactivated" | Tee-Object -FilePath $transactionLogPath;
#Check who runs the script
"$env:userdomain\$env:username" | Tee-Object -FilePath $transactionLogPath -a;
catch
"$(Get-Time) An error occurred. $_" | Tee-Object -FilePath $transactionLogPath -a;
from the above script you can see, I added a line to see who runs the script. After BatAction triggers, here is the output
01-29-2022 16:35:52 - Output Deactivated
ComputerName\Administrator
Furthermore, I’ve tested these example in different workstations and VMC product (Expert). This is my sixth script that I designed to do the same task I originally intended to do with no luck.
Now regarding the cmdlest “Invoke-WebRequest”, I found that I needed convert the credentials to “ToBase64String” and pass it to a header using “Basic Authentication”.
When I invoke the URL on Web browser, Linux terminal, Python, PHP, C++ script, it works with no error. It seems “Invoke-WebRequest” doesn’t know how to handle the request if authentication type is not specified (At least this is case in my situation).
