I need to populate an event database into an new EventServer with data from another existing EventServer (unconnected).
It might be that objects cause of the events are unknown in the new system (unknown GUIDs in the new system), I just need a large event database to be read from the new system for test issue.
Are there export and import commands (into/from files) for this ?
