External in C++ Trigger event
Hi all,
I would like trigger analystic event from external system. My system is emplemented in c++.
Could you please suggest to me which sample code could help. Currently, i’m investigating How to call a managed DLL from native Visual C++.
Thank you in advance!
My best advice is that you take the “Analytics Event trigger via XML” and translate it into C++. It is a relatively small sample that does not use any dependent dll’s from the SDK.
