Failed to install XProtect essential+ Trial version
I was trying to use APIs, but encountered an issue when installing the XProtect Essential+ Trial version. It failed with the attached installer logs.
Could someone please provide assistance with troubleshooting?
Thanks,
Nick
As this does not pertain to development but to a general situation you will most likely get better help from the partners active in the Support Community - https://supportcommunity.milestonesys.com
will do. thanks for the info.
