When I trying to install VMS 2017 R2, I got following error and failed installation.
My environment is
Windows 10 64 bit
How can I solve this problem?
2019/03/23 3:01:48 Error エラーが発生しました: ‘’。エラーの詳細:
2019/03/23 3:01:48 Error Install failed.VideoOS.Installer.Sequencer.ErrorHandling.InstallerSequencerException
Server stack trace:
場所 VideoOS.Installer.Sequencer.SequenceManager.Install()
場所 System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
場所 System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
場所 System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
場所 System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
場所 VideoOS.Installer.Sequencer.SequenceManager.BeginInstallDelegate.EndInvoke(IAsyncResult result)
場所 VideoOS.Installer.UI.WizardPageInstall.InstallationEnded(IAsyncResult ar)
