When a problem occurred on an external application to work from XProtect system independently, I want to notify XProtect system of an alert or an event using MIP SDK.
When I make application in C++ or C#, please tell me if there are a sample and past topics to serve as a reference.
You can trigger a user-defined event, you can see this in the ConfigAccessViaSDK sample.
Perhaps you want something more advanced, perhaps this -
https://force.milestonesys.com/support/articles/en_US/How_To/Create-an-alarm-from-a-MIP-SDK-based-application
Hi Andersen
I thank for your quick answer.
I confirm the information that you taught, and I challenge it.
I confirmed a sample program.
However, an event did not seem to be able to transmit a message.
I confirm whether an event occurred in the XProtect side in a log file.(RecordingServerYYYYMMDD.log)
Does the sample fit by following how to use?
①I choose a camera from “List of all defined items:”
②I add a target event from “Select Instance” button
③I click “Trigger” button
④I choose a camera from “Item Picker” and click “OK”
*The edition of XProtect is Enterprise
Hi Andersen !
And, by your information, I was able to solve a question.
I am very grateful to you.
