Greetings all,
We are trying to get logs, events, and alarms from the gateway API in milestone 2023 R1, however I didn’t find any GET in the REST API regarding the logs.
then when I tried to access the EvetnAPI/AlarmAPI am getting:
“error”: {
"httpCode": 404,
"details": \[
"errorText": "Unknown resource: events"
based on the documentation the API endpoint is :
https://servername.com/api/rest/v1/events
how can I get logs from the REST API and how to access the EventAPI and AlarmAPI.
regards.
The Events API and the Alarms API were both added as beta functionality in 2023R2. You cannot use this in 2023R1. I recommend that you upgrade and use the newest version of the XProtect VMS, currently this is 2023R3.
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/mip2023r2_intro.html&tree=tree_home.html
https://doc.developer.milestonesys.com/mipvmsapi/api/events-rest/v1/#section/Quickstart/Requirements
Thank you for the feedback,
what about the logs? are they considered under Event/Alarms? or are they not available in the API itself.
The API Gateway has logs here. [C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) API Gateway\Logs
I mean Milestone Server logs, such as “Server Logs”, “Audit Logs”, “Rule Logs”.
if they are available in the gateway API, can you specify in which endpoint are they.
Those logs are currently available only when using the MIP Library.
You can see a sample that shows how to use this here: https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/logread/readme.html&tree=tree_2.html
I do not have any indication when the access to read these logs might be added into the Rest API. I can only say that it is the intention that more support will be put in the Rest API.
