Can we generate camera events(motion detection) programmatically using SDK?
Thanks,
Vega
Thanks,
Vega
No.
I assume you have a regular camera using a camera driver from Milestone because if you are developing your own camera driver (for your own device or for an existing device) you can control this.
Facing issue with stableFPS - https://supportcommunity.milestonesys.com/s/feed/0D5bH00000B1HlgSAF?language=en_US
This could happen with any camera, if you have motion always you will never get a motion started event.
There is an element of guessing, if you do have a camera source with motion, no motion, motion then you should see the events.
