Generic Audio Device to listen to/record from
Does there exist a generic driver that can be used to listen to and record from a generic audio streaming device?
The streaming could be done via HTTP/UDP/TCP in G711-ulaw.
Thanks, Sebastian
Sure, the “generic” Milestone drivers are:
* ONViF single channel driver
* ONViF 2-16 channel driver
* Universal 1 channel driver
* Universal 16 channel driver
* Universal 64 channel driver
* DirectShow driver
I would recommend starting with the Universal 1-channel driver, which is very adaptable for “unknown” devices
