Get camera/hardware guid
Hi All,
we are developing a driver with DriverFramework.
There is a way to obtain the camera / hardware guid from inside the driver?
We need to obtain the VideoOS.Platform.ConfigurationItems.ConfigurationItem
Futhermore, we can create a task of kind RetrievalTask from RetrievalTaskManager?
Thanks in advance
No.
The driver should never contact the VMS. It should be single minded about communicating between a device and the recording server for the purpose of acting as a driver.
The question has come up before, exactly when it comes to retrieval. I guess you want to signal to the VMS that it should ask for retrieval. You must do this in a separate service, you must not do it from the driver.
