Thank you Bo, but unfortunately this code doesn’t work - it compiles fine in Visual Studion (no errors), but when I click on the button in Smart Client, it throws an error:
************** Exception Text **************
Exception type:System.MissingMethodException
Exception message:Method not found: ‘System.String VideoOS.Platform.Login.LoginSettings.get_FullyQualifiedUserName()’.
Exception source:ActiveElementsOverlay
Exception Target Site: ButtonExtra_Click
at ActiveElementsOverlay.Background.ActiveElementsOverlayBackgroundPlugin.ButtonExtra_Click(Object sender, RoutedEventArgs e)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
************** System Info **************
Date and time: 12/20/2019 3:16:57 PM
Machine Name: DESKTOP-OILDD1G
Processors count: 8
OS version: Microsoft Windows NT 6.2.9200.0
64 bit OS: True
64 bit process: True
IP address: fe80::e4b0:af90:ab52:2450%10 (DESKTOP-OILDD1G)
Current user: DESKTOP-OILDD1G\KnowFalls
Product version 13.1.141.1
Execption log: [C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Smart Client\Exceptions\ExceptionLog_2019-12-20T03.16.57.1037.xml
