We would like to know if the cameras can be moved e.g PTZ cameras,
and the camera location, where can we find that info?
In the result from Server Command Service GetConfiguration you find PtzSettings which contain information about the PTZ capabilites of the camera.
If you with location mean the coordinates, how the camera is turned (pan, tilt and zoom) you get this from Recorder Command Service using the PTZGetAbsolutePosition method.
