Get Event details and information from camera or alarm to my node js server
Hello guys ,
i am new here and this is my first time i will use milestone and all these software
i have a vm server with MIP sdk installed with all it products such as xprotect smart client , and management and so on ,
i need to read the signals or events that comes from camera or alarm for example
i have node js server and i need to read these signals from milestone to my node js server .
i completely have no idea what should i do or where to start
i saw in the documents that using a 3rd party app , i must choose component integration , i am not sure if i understand correctly
can anyone help to point me in the right direction
thanks
Four hints..
If you are using some kind of javascript you will probably have to use protocol integration methods.
http://doc.developer.milestonesys.com/html/index.html?base=content_3.html&tree=tree_3.html
You will have to get an understanding of the login to Milestone XProtect requiring NTML (or SSL)
For events and alarms you will have to use alarm client protocol.
http://doc.developer.milestonesys.com/html/index.html?base=reference/protocols/alarmcommand.html&tree=tree_3.html
There is an AlarmList sample, it is written in c# but it uses protocol methods that should be easy to “translate”. Maybe you can use this to get a head start.
http://doc.developer.milestonesys.com/html/index.html?base=samples/alarmlist_sample.html&tree=tree_3.html
Thank you for your answer and help,
however i am still confused and lost …
i have no idea where to start , all i see is c# codes and xml files
i cant see a good guide or tutorial that will guide me step by step on how can i connect or retrieve data from my camera using my node js server or any javascript code .
please help me as much as you can i know that idea that i am new to this will be tiring i am sorry for that
The Soap services and protocols are only documented, samples are to a very large extent all c#, there is no eLearning or tutorial on Soap or protocols.
So what am i suppose to do now? what do you suggest i should do to be able to make this task done , and read data from the server using JavaScript , please i am suffering since a week could not find anything or anyone to help
