Get monitor object of a Xprotect Smart client application with component SDK
With the component SDK, is it possible to get a list of monitors of a XProtect Smart Client, and then request to show cameras at specific positions?
Or is it only possible to do it with a XProtect Smart wall?
This is only possible with the XProtect Smart Wall.
Depending on the specifics you might be able to develop a Smart Client plugin that can display a camera at a specific position. I recommend that you explore the Smart Client View and Window Tool sample, see how you can send a camera to a position through code.
http://doc.developer.milestonesys.com/html/index.html?base=samples/smartclientview_windowtool_sample.html&tree=tree_1.html
