Using 2023 R2 SDK.
Using ServerSideCarrosal, we get exceptions when SQL is down and we drag/drop the server side carrosal plugin in SC view.
************** Inner Exception **************Exception type:VideoOS.Platform.RestApiMIPException
Exception message:GET Unexpected statuscode BadRequest in ‘http://v21.demo.ve5.com/API/rest/v1/mipKinds/8a9f28e8-042e-480d-be46-a690537ecee6/mipItems?definitions&tasks&resources&disabled’ - A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
Exception source:VideoOS.Platform
Exception Target Site: MoveNext
at VideoOS.Platform.Proxy.RestApi.RestApiClient.d__28.MoveNext()
Exception type:System.AggregateException
Exception message:One or more errors occurred.
Exception source:mscorlib
Exception Target Site: GetResultCore
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at VideoOS.Platform.Proxy.RestApi.RestApiClient.GetResources(String resourceType, String id, String childResourceType)
at VideoOS.Platform.Proxy.RestApi.RestApiClientDecorator.CallWithRetry[TResult](Func`2 call)
at VideoOS.Platform.Proxy.RestApi.RestApiClientDecorator.GetChildItems(String path)
at VideoOS.Platform.Proxy.ConfigApi.ConfigurationApiItemWrapper.Children()
at VideoOS.Platform.ConfigurationItems.MIPItemFolder.get_MIPItems()
at VideoOS.Platform.Configuration.GetItemConfigurationsBase(ServerId serverId, Item parentItem, Guid itemKind)
************** System Info **************
Date and time: 12/10/2023 9:55:43 PM
Machine Name: V21
Processors count: 24
OS version: Microsoft Windows NT 6.2.9200.0
64 bit OS: True
64 bit process: True
IP address: fe80::c418:2a8c:813a:2b69%13 (V21.demo.ve25.com)
Current user: V21\vegad
