Getting empty images from image server: --> b''
:disappointed_face: Here is my code snippet in python:
[#TO](javascript:void(0); β€œ#TO”) CONNECT TO IMAGE SERVER
r3 = β€œ<?xml version='1.0' encoding='utf-8'?>0connectgavinsoh{camera_guid}yesyesid={camera_guid}&connectiontoken={token}”.format(camera_guid = camera_guid, token =token)
r3_1 = r3 + β€œ\r\n\r\n”
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect((β€˜192.168.1.13’, 7563))
r3_bytes = bytes(r3_1, encoding=β€œUTF-8”, errors=β€œreplace”)
s.sendall(r3_bytes)
while True:
test = s.recv(4096)
print("Received after connect request: " + test.decode(β€˜utf-8’))
break
[#TO](javascript:void(0); β€œ#TO”) GET IMAGES FROM IMAGE SERVER
dt = datetime.datetime.now()
epoch = datetime.datetime.utcfromtimestamp(0)
TEST = (dt - epoch).total_seconds() * 1000.0
print(TEST)
r4 = β€œ<?xml version='1.0' encoding='UTF-8'?>0goto” + str(TEST) + β€œβ€ + β€œ\r\n\r\n”
[r4](javascript:void(0); β€œr4”) = β€œ<?xml version='1.0' encoding='UTF-8'?>1liveno” + β€œ\r\n\r\n”
s2 = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s2.connect((β€˜192.168.1.13’, 7563))
print(β€œconnected!”)
r4_bytes = bytes(r4, encoding=β€œUTF-8”, errors=β€œreplace”)
s2.sendall(r4_bytes)
while True:
img1 = s2.recv(1024 * 64)
[img2](javascript:void(0); β€œimg2”) = img.decode(β€˜utf-16’)
[img3](javascript:void(0); β€œimg3”) = bytearray(img2, β€˜utf-16’)
print(img1)
I am trying to send a request and get binary JPEG bytes back as a response so that I can work with it but so far I have been getting back β†’ b’’
empty byte strings for some reason. Can someone please shed some light on the matter? Thanks.
I am very sorry that we overlooked this post. Could you please let us know if you have already found a solution to this?
