Getting error on video export
I am new to milestone i have requirement to export video from milestone via third party application. I use sample code i.e videExport provided in web example. I getting error on calling XPMobileSDK.getThumbnailByTime. Error: The application has lost connection due to connectionRequestResponseIsTerminal
(function (undefined) {
  function ExportController() {
    var cameraItem;
    var container;
    var progressIndicator;
    var image = document.createElement('img');
    var canvas;
    var canvasContext;
    var exportId;
    function getThumbnailCallback(thumbnail, timestamp) {
      const imageBlob = b64toBlob(thumbnail, 'image/jpeg', 512);
      var imageURL = window.URL.createObjectURL(imageBlob);
      image.src = imageURL;
    function b64toBlob(b64Data, contentType, sliceSize) {
      const byteCharacters = atob(b64Data);
      const byteArrays = [];
      for (let offset = 0; offset < byteCharacters.length; offset += sliceSize) {
        const slice = byteCharacters.slice(offset, offset + sliceSize);
        const byteNumbers = new Array(slice.length);
        for (let i = 0; i < slice.length; i++) {
          byteNumbers[i] = slice.charCodeAt(i);
        const byteArray = new Uint8Array(byteNumbers);
        byteArrays.push(byteArray);
      const blob = new Blob(byteArrays, { type: contentType });
      return blob;
    function getThumbnailErrorCallback(error) {
      alert('Error getting thumbnail. Code: ' + error.code);
     * Request thumbnail for given time
    function getThumbnail(event) {
      event.stopPropagation();
      // This is the time you request from the server
      // You can set it to any valid timestamp
      var thumbnailTime = Date.now();
      var params = {
        cameraId: cameraItem.Id,
        width: 400,
        height: 225,
        time: thumbnailTime
       * Requesting a thumbnail.
      XPMobileSDK.getThumbnailByTime(params, getThumbnailCallback, getThumbnailErrorCallback);
    function onImageLoad(event) {
      canvas.width = image.width;
      canvas.height = image.height;
      canvasContext.drawImage(image, 0, 0, canvas.width, canvas.height);
    function startExport() {
      // generate start and end time of the export with duration of 10 s
      var end = new Date().getTime();
      var start = end - 10000;
      var exportRequest = XPMobileSDK.startVideoExport(cameraItem.Id, start, end, startExportCallback, exportError);
    function exportError(error) {
      alert('Error on export. Code: ' + error.code);
    function startExportCallback(expId) {
      exportId = expId;
      updateStatus();
    var updateStatus = function () {
      XPMobileSDK.getExport(exportId, getExportCallback, exportError)
    function getExportCallback(status) {
      // update UI
      progressIndicator.style.width = status.State * 3.8 + 'px';
      // continue with the refresh or downlaod the prepared export
      if ((status.State >= 0) & (status.State <= 100)) {
        setTimeout(() => { updateStatus() }, 1000);
      else if (status.State == 101) {
        downloadExport(XPMobileSDKSettings.MobileServerURL + "/" + status.Link);
    var downloadExport = function (url) {
      var a = document.createElement('a');
      a.href = url;
      a.download = 'download';
      a.click();
    function addExportButton() {
      var overlay = document.createElement('div');
      var progressBar = document.createElement('div');
      progressIndicator = document.createElement('div');
      progressIndicator.id = "progress-indicator";
      var button = document.createElement('button');
      function stopPropagation(event) { event.stopPropagation(); };
      progressBar.appendChild(progressIndicator);
      progressBar.classList.add('progress');
      progressBar.addEventListener('click', stopPropagation);
      overlay.classList.add('cloak');
      overlay.addEventListener('click', stopPropagation);
      button.classList.add('start-export-button');
      button.addEventListener('click', (event) => {
        getThumbnail(event);
        startExport();
      button.innerText = 'Start export';
      container.appendChild(overlay);
      container.appendChild(progressBar);
      container.appendChild(button);
    function init(event) {
      cameraItem = event.detail.cameraItem;
      container = event.detail.cameraContainer;
      image.addEventListener('load', onImageLoad);
      canvas = container.querySelector('canvas');
      canvasContext = canvas.getContext('2d');
      addExportButton();
    return {
      init: init
  var connectionDidLogIn = function () {
    var container = document.getElementById('export-container');
    Application.connectionDidLogIn(container);
    container.addEventListener('cameraElementAdded', function (event) {
      var thumbnailController = new ExportController();
      thumbnailController.init(event);
  window.addEventListener('load', function () {
    var params = {
      connectionDidLogIn: connectionDidLogIn
    LoginManager.loadAndLogin(params);
Hello Donny,
can you check if there are something suspicions in the Mobile server log usually located at [C:\ProgramData\Milestone\XProtect Mobile](file:C:/ProgramData/Milestone/XProtect%C2%A0Mobile) Server\Logs
You can also attach it here so we can also have a look to search for some clues.
Kindly regards
Asen
