I am creating a Client Plugin that gets information of server plugin settings.
I need to retrieve Server plugin settings from inside Client plugin using SOAP protocol.
I save configurations using the following code inside client plugin:
var confs = Configuration.Instance.GetItemConfigurations(ServiceTestDefinition.ServiceTestPluginId, null, ServiceTestDefinition.serverConfigKind);
Item CurrentItem = new Item(confs[0].fqid, "AyonixDatabase");
CurrentItem.Properties["connstring"] = "VALUE I WANT TO SAVE";
CurrentItem.Properties["cameraservicepath"] = "ANOTHER VALUE I WANT TO SAVE";
Configuration.Instance.SaveItemConfiguration(ServiceTestDefinition.ServiceTestPluginId, CurrentItem);
I want to use the following SOAP call to retrieve settings on client plugin:
public XmlDocument GetCustomSettingDataUser(string url, string token, string guid, AuthenticationType autype)
try
string templ =
"<?xml version=\"1.0\" encoding=\"utf-8\"?>" +
"<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\" " +
"xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" " +
"xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\">" +
"<soapenv:Body><GetCustomSettingDataGlobal xmlns=\"http://videoos.net/2/XProtectCSServerCommand\">" +
"<customSettingId>{0}</customSettingId><token>{1}</token></GetCustomSettingDataGlobal>" +
"</soapenv:Body></soapenv:Envelope>";
//Guid guid = Guid.NewGuid();
string content_str = string.Format(templ, guid, token);
XmlDocument doc = GetSoap(url, content_str, ServiceType.Server, "GetCustomSettingDataGlobal", autype);
return doc;
catch (Exception e)
string s = e.Message;
return new XmlDocument();
However, I cant retrieve values using this call. Am I using the correct SOAP call?
Which identifier should I use on this call to retrieve these results?
How
