Hi!
We are using Milestone Protocol integration to validate user token received from Plug-in integration.
In most cases it works fine, but on a specific customer’s environment, when user authorizes as current Windows user, he’s getting Unauthorized (401) error.
Are there any cases when soap protocol integration can’t validate current Windows user’s token? Or there are any ways to debug it?
Plug-in integration code (getting of token):
Platform.Login.LoginSettings ls = Platform.Login.LoginSettingsCache.GetLoginSettings(Platform.EnvironmentManager.Instance.MasterSite);
return ls.Token;
Protocol integration code (validation of token):
[System.Web.Services.WebServiceBindingAttribute(Name = "ServerCommandServiceSoap", Namespace = "http://videoos.net/2/XProtectCSServerCommand")]
public partial class ServerCommandService : System.Web.Services.Protocols.SoapHttpClientProtocol
public ServerCommandService(string url) : base()
this.Url = url;
this.Credentials = CredentialCache.DefaultNetworkCredentials;
[System.Web.Services.Protocols.SoapDocumentMethodAttribute(Action = "http://videoos.net/2/XProtectCSServerCommand/GetUserInfo", RequestNamespace = "http://videoos.net/2/XProtectCSServerCommand", ResponseNamespace = "http://videoos.net/2/XProtectCSServerCommand", Use = System.Web.Services.Description.SoapBindingUse.Literal, ParameterStyle = System.Web.Services.Protocols.SoapParameterStyle.Wrapped)]
public UserInfo GetUserInfo(System.Guid instanceId, string token)
object[] results = this.Invoke("GetUserInfo", new object[] {instanceId, token});
return ((UserInfo)(results[0]));
Thanks in advance.
