Hi, we recently started to using IConfigurationService.GetChildItemsHierarchy instead of IConfigurationService.GetChildItems (recursively) to improve loading time when fetching device information on larger systems.
This works fine on for example my system (2024 R2), when calling IConfigurationService.GetChildItemsHierarchy on a recording server item specifying ItemTypes:
- Camera
- Microphone
- InputEvent
- HardwareDeviceEvent
However, a customer reported having som problems with this on 2022 R3.
It seems like the same call will return cameras (and possibly microphones and inputs), but NO HardwareDeviceEvent.
I’m just wondering if you know if the support for ItemTypes has been extended in later versions that could explain why we get different behavior on different versions of XProtect.
