I managed to get the token from the Management Server using basic credentials and am now trying to connect to the ImageServer. My XML message is as below:
<?xml version="1.0" encoding="UTF-8"?>
<methodcall>
<requestid>1</requestid>
<methodname>Connect</methodname>
<username>dummy</username>
<password>dummy</password>
<cameraid>(camera guid)</cameraid>
<alwaysstdjpeg>yes</alwaysstdjpeg>
<connectparam>id=(camera guid)&connectiontoken=TOKEN#677d2185-c4e4-4caa-a30e-09229399b38e#(host name)//ServerConnector#</connectparam>
</methodcall>
Before converting it into a byte array, I added the “\r\n\r\n” as per the documentation.
I open the socket connection like this:
Socket clientSocket = new Socket("(ip address)", 7563);
No error came up when I open the connection and send the byte array message but when I try to get the response, I get an error. It seems that the server is not giving back a response so I am not sure if there is something wrong with my url, XML message or how I am sending the message
EDIT: I’m using Milestone Essential btw
