Since the plugin must perform some scheduled operations it is necessary that it is always active on the platform and it would be very useful if it could start with the platform and not at user login.
Can anyone give me some examples or information on how to do it?
does the service use “Component Integration”? I think so, and if I’m right, there will be the same malfunctions previously verified regarding video exports
Thank you Rio, after sending you the email I made some reflections coming to the conclusion that I must use the “Component Integration” technique and I already found an example of hard-coded login.
About “malfunctions” (bugs) I discovered, using Component Integration for Video Export in Milestone format:
If there is even only an hole in the recording interval the process abort with message “Recording Server is offline –“ (including the dash at the end)
The export directory doesn’t contain the player even if it is required
Using cryptography the client requires as many passwords as there are cameras (my customer has about 100 cameras )
I send a lot of snapshot about such behavior to Bo; if you are interested a can send them to you
The issue you reported on the DBExporter will be relevant. Let us hope that the support case in which you have cooperated and supplied logs and other information will lead to a solution soon.
