Hello, we are using the MIP SDK to develop one new plugin now. But there are some questions could you help me?
1. But we got the error from event server. AlarmSecurityCredentials Unhandled exception in web service with message: the messages are over the threshold, 2000000.
2. May I know how can I trigger and send the alarm event from sc client?
  1. Can you please explain what you have done, what you did for troubleshooting and what you observe?
  2. This Library Event Generator sample shows how to generate and send an Analytics event to the Event Server, please see this - https://doc.developer.milestonesys.com/html/index.html?base=samples/libraryeventgenerator_sample.html&tree=tree_2.html
This Analytics Event Trigger via MIP .Net library sample demonstrates how to submit an Analytics Event to the Milestone XProtect Event Server using the .Net library.
https://doc.developer.milestonesys.com/html/index.html?base=samples/analyticseventlibrary.html&tree=tree_2.html
There are component samples but you can use them as plugin samples. Please explore them.
