I already have a camera added to Xprotect, but how do I send metadata to this camera?, I was trying to send it with Multi Channel Provider project that was on the samples
You might be missing following – “Create a link between a camera and the new metadata device by selecting the camera, then choose the “Client” tab and finally add the metadata device to the “Related metadata:” list.”
thanks for the recomendation, but I tried to run the sample (by the project code on Visual Studio) and it not works, I followed step by step, but it just do not work, I am running the sample, created the MIP driver device on port 52123, linked a camera to it, enable the bounding boxes on Smart Client, but nothing appears to my camera
Start the Smart Client and choose the camera. Make sure to check in setup mode that bounding boxes are enabled and that the new metadata device is in the “Bounding Box Providers” list.
I added 2 posts on this thread, because it allows me to add only 10 pictures and I explained with 15 pictures. Again, can you please check it thoroughly again?
It is perfectly clear with the screen capture. Your Bounding Box provider is not connecting to the server (sessions=0), which means it can send no data.
Check licensing, check network, double-check port and password..
