Hi Everyone, one question, i am invoking the SOAP protocol on the Milestone Server. Do I need to have a certificate on the client????. Also, i want to know if in the server side there is a log file (when someone does invocations on the server).
If you have an encrypted server then you need to have a certification for the client. Please see this document, it might be helpful –
https://milestonedownload.blob.core.windows.net/files/XProtect%202019%20R2/Manuals%20and%20guides/Advanced%20VMS/Guides%20and%20documents/Certificates%20guide/MilestoneXProtectVMSproducts_CertificatesGuide_en-US.pdf
If you look in [C:\ProgramData\Milestone\](file:C:/ProgramData/Milestone/) , there is a folder for each major server component and there are log files. Also, debug logs is [C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Management Server\Logs.
You can access most server logs through the Management Client. See -
https://doc.milestonesys.com/latest/en-US/standard_features/sf_mc/sf_mcnodes/sf_8serverlogs/mc_serverlogs.htm
I can’t tell which log would be most useful for you but please explore the above.
