We have a project in Korea, after internal analysis, we think the issue may be caused by Milestone side.
There are two problems. First, we can’t receive real-time alarm on developed tab(which insert on Smart Client ourselves), because the plated is full of limited sql database of Milestone(about 10G). Second, we can’t search data.
We know Milestone provide about 10G database for free, if we need more storage, we should buy service from Milestone. The issue is when the 10g database if full of plate, wired problems happened.
The database is full now, then we can search nothing by API of MIP SDK.
The following are the details about MIP SDK development, hope it will be helpful, if further details needed, we are pleased to provide.
Also if remote access needed, we will try to provide.
1.We can’t receive, because the database is bigger than 10G.
We found there are two alarm information on Milestone original tab.
2. We can’t search history, because we get 0 after call corresponding API of MIP SDK. The following is the log.
The following is the code which used corresponding API:
