How can i get a camera details via Web service? my input will be the camera name (or its GUID id).thanks.
Are you using the Server Command Service GetConfiguration?
What kind of camera details?
@Bo Ellegård Andersen (Milestone Systems)​ i want to get the camera name and FQID xml .
So the reply is Server Command Service GetConfiguration or SystemInfo.xml. In c-code you can do both in e-code you can use the latter.
As mentioned in MIP Doucmentation in Protocol and Product Support Information - Support for Server Command Service:
GetConfiguration: No / Yes / XProtect Enterprise, Proffessional and Express uses Image Server to provide configuration via the SystemInfo.xml file.
