I’ve been trying to replicate the tcp viewer example on NodeJs (more specifically, Electron), and i’ve got really far, to the point where i can actually show some images on the screen, my question is, how does the canvas element on the TCPViewer render images?
So far, i’ve been able to stablish a TCP socket connection with the recording server, and started a live requests which sends me 1 of 2 responses possible for that kind of request, LivePackageMessage or GoTo response. After that i split the data by the bytes 13-10-13-10 so as to know when every response is finished, and following the TCPViewer example whenever the data starts with a 255 byte(0xFF) followed by a 216 byte (0xDB) i can be sure that what follows is an image. So by that point i try to draw the images inside a HTML 5 canvas element using a HTML5 img element.
This works, kind of fine, but not as near as good as the TCPViewer example, its really choppy and not fluid at all.
As far as i can tell, the TCPViewer example does something quite similar, but it works a lot better, the video looks really good.
Can some explain me why? how does the canvas element on the TCPViewer example work?
Thanks in advance
