I’m working with the Milestone MIP SDK Config API Client sample and noticed that Hardware items expose an “Update firmware” method that can be invoked via IConfigurationService.InvokeMethod(). When triggered, the server returns an InvokeInfo item containing a single input field called Storage ID.
I understand the general InvokeMethod pattern — the server drives the UI dynamically and we pass the filled InvokeInfo back to trigger the actual operation. What I’m unclear about is the firmware file delivery side.
My questions:
What exactly is the Storage ID expected here — is it the GUID of a Recording Server Storage, or something else entirely (e.g. a session upload ID)?
If I have a firmware
.binor.zipfile on my local system, what is the correct way to make it available to the VMS before callingInvokeMethod? Is there a separate API call to upload the file first, or does the Recording Server need to have the file placed in a specific folder on the server machine? -
Is there a
UploadFirmwareor similar method that should be called beforeUpdateFirmwareto get a valid Storage ID back? -
Does this work for all hardware drivers, or only for specific camera models/drivers that support firmware upgrade through the MIP SDK?
