I would like, in a Management Client MIP Plugin, to access a couple of “settings” associated to an hardware device, more specifically the “HTTPS Validate Certificate” and “HTTPS Validate Hostname”.
Those are not available as “Properties” of the camera Item.
I had a look at the SDK documentation and I tried the “ConfigAccessViaSDK” application but it does not seem to be able to retrieve those settings.
Is it possible? Someone already did it?
Thanks!
