How to Check Patch Installation Status Across XProtect Components
After applying a patch to the XProtect components, is there any way to centrally verify the patch installation status other than checking the patch installer logs on each server?
For example, is there any XProtect management tool or other method that shows which components or servers have the patch installed?
Thank you for your help.
There are no tools or APIs in the MIP SDK for managing installations or patches.
This forum focuses on software development with the MIP SDK and integrations with Milestone XProtect®. Because your question is about installation and patch management rather than SDK development, our Support team is better equipped to help.
For further assistance, please create a technical support case through the Milestone Support Portal.
Thank you for the clarification.
I understand that my question is not related to MIP SDK development and that I submitted it to the wrong place.
I will contact the Milestone Support team through the Support Portal instead.
Thank you for your guidance.
