Whats is the best way to create load of hundreds stream in our load environment and to check the system before deployment ?
If possible we need that the streams will olso go via the OnVIF Bridge.
Regards,
Nir
Regards,
Nir
We are at Milestone working on a tool that will make it easy to introduce “fake” test cameras and simulate a high number of cameras. This tool will be in MIP SDK 2019 R1.
Thank you for the answer.
Is there known release date ?
