Good day.
How are you ?
I am interested in the possibility of creating a Plug-In that configures the analytic parameters that I want to receive from an IP Addresss.
(I do not know if it s better to refer to is as Plug-In or PlugIn, so I might use both expressions)
I want to send the data from that IP Address via HTTP POST so a Milestone Event triggers when receiving it.
Then, if that event data is among the boundaries configured in the Plug-In; I want the XProtect Smart Client to receive the data and present it to the user
The data is a custom image detection I require.
As a close enough example:
Let’s say that it detects Vehicle License Plates.
My system analyses the video and detects those License Plates.
When it detects one, it generates a JSON data and sends it via HTTP POST.
I want to receive that data in the XProtect Event Server, analyse the data using the configuration of the Plug-In.
Check if the data suits the parameters that are configured.
And finally, show the data to the user in XProtect Smart Client.
1.- What steps do I have to take ?
2.- Do I have to start by creating the PlugIn for the configuration?
3.- How do I create an Event Handler at the Event Server to handle my HTTP POST request to Milestone?
4.- How do I send the data fom the Event Server to XProtect Smart Client if it suits the configuration I have defined in the PlugIn (2.-) ?
They are many questions, I know.
I have checked the YouTube videos about the installation of simple PlugIns,
but there is no information about Event Handlers of how to develop them.
MIlestone XProtect seems like the suitable VMS for what our company requires, but we need to know if this application is possible to develop and a few guide steps would be helpful.
Thank you very much for reading this long post, I tried to sum up everything in one post, although maybe I should have divided it into several of them;
but since I do not know the required steps to achieve this goal, I had to ask everything.
Again, thanks and have anice day.
