How to create/delete preset on the Corporate?
I’m using the XProtect Corporate version.
and I want to create or delete preset.
But,
in the ComponentSamples > PTZandPresets sample project
=> I cannot
in the protocol support information
=> CreatePreset, DeletePreset does not support on Corporate
Is it right?
If it right.. How do I create/delete the preset on the Corporate?
protocol integration or component intergration anyway OK.
plz help me.
It is correct what you have found and describe.
You can create PTZ presets using the Configuration API which works for XProtect Corporate (and Expert and Plus versions).
Explore the Config API Client to get a first climpse of the possibilities and how to work this API.
