I’m using Milestone version 2025 R3 x64.
I’m trying to debug my event server plugin with vs2019 without success !
To ensure that the plugin is always the correct version in ‘MIPPlugins’ folder, I added a Post-build event command in the project properties and copy works fine.
In the debug properties, I requested the launch of: C:\Program Files\Milestone\XProtect Event Server\VideoOS.Event.Server.exe -x
First, I make sure that the service is stopped, and then, when I run my plugin, the event server launches correctly in windowed mode.
Next, I launch XProtect Management Client.
When I try to add my plugin in the “Access Control/Systems” section, I get the following error message:
Create Access Control System Integration
No access control plug-ins are available. Verify that plug-ins are installed on the event server and that the Event Server service is running.
In addition, I also have a warning about breakpoints in my source code that says:
The breakpoint will not currently be hit. No symbols have been loaded for this document.
Could you help me?
