Hello all,
The scenario is:
I’m creating a Management Client plugin.
In the plugin definition class I’m overriding the SecurityActions property and I’m setting three security actions for the plugin:
securityAction1
securityAction2
securityAction3
I run the Management Client with the plugin, on the Security/Roles/Overall Security the 3 security actions are there, under the plugin node.
Let’s say I change my mind and I want to have only two security actions for the plugin.
I’m deleting the last entry from the overriden SecurityActions property in the plugin definition class. So now I only have:
securityAction1
securityAction2
I rebuild and start the Management Client.
In the Security/Roles/Overall Security window there are still three security actions, although in my plugin definition I only have two.
It seems that I am unable to get rid of the security actions once I’ve exposed them through the plugin definition property!?
Is there a way to programmatically delete these security actions that you define for your plugin?
Thanks for your time.
