I’m on a LAN where there is no DNS set-up. I’m trying to access to Milestone SDK from another PC.
1st, I am trying to get information about the services avaiiable, so I’m doing a get on the following url:
http://192.168.3.141:80/rcserver/siteinfo.xml
The problem is that it returns :
<?xml version="1.0" encoding="utf-8" standalone="yes"?><methodresponse><userok>yes</userok><userid>win8-dev\hhervoche</userid><siteinfo protocolversion="1.0.0.0"><site><name>WIN8-DEV</name><id>1185D65D-ED0D-41A7-B8FF-EC5367CC4749</id><description /><lastmodified>28/06/2019 13:36:09</lastmodified><laststatushandshake>28/06/2019 13:36:09</laststatushandshake><connectionstate>Attached</connectionstate><addresses><address url="http://win8-dev/" type="Server" /></addresses><serverversion>13.1.0.1</serverversion><serviceaccount>AUTORITE NT\SERVICE RÉSEAU</serviceaccount><synchronizationstatus>0</synchronizationstatus></site><parent /><childs /></siteinfo></methodresponse>
the adress url field is filled with a name "http://win8-dev/ "instead of the raw IP address (it should be “http://192.168.3.141:80” in my opinion). Is there a way to change it on Milestone settings ?
Maybe I’m doing it wrong and there is a much proper way to get the server address & protocols based on the hostname?
