In My Application is already integrated to XProtect Essential
after then, I got a Corporate license.
So, Install the XProtect Corporate 2017 R1 and try to login → but FAIL
Using the Smart Client then login OK
-> but, I find the stream using the https 443 port
So..
1. I want to use the basic authentication only via http not https
How to disable the https?
What you see here is exactly the dfference in the implementation of basic users when you compare XProtect Essential and XProtect Corporate. You cannot disable. See
https://force.milestonesys.com/support/articles/en_US/FAQ/MIP-SDK-applications-and-basic-users-in-XProtect-Corporate-or-XProtect-Expert
Note that XProtect Essential is not open for integration, you should use XProtect Express as minimum.
Thanks.
So.. You mean..
When I want to use the XProtect Corporate
and I want to use only the http then
-> must use the windows authentification
Is it right?
