From a background plugin (event server), I want a list of all child sites.
How can I do this?
How can I do this?
The goal is to connect an alarmclient to each sub site and be able to get alarmlist for all sites
@Bo Ellegård Andersen (Milestone Systems) or @Rie Kiuchi (Milestone Systems) could you please help?
Please see the MultiSiteViewer sample, how it log in on multiple sites. Also; the Multi-Site Status Viewer actively opens for multiple MessageCommunication targets, the task you have is similar.
@Bo Ellegård Andersen (Milestone Systems) Thanks for your reply! I checked this sample again, and noticed I forgot to do a part of the code. I’m able to open an alarmclient to a different site.
The only problem I’m still facing is to get a list of subsites. When I do this from event server plugin, I get 0 items:
Item item = EnvironmentManager.Instance.GetSiteItem(EnvironmentManager.Instance.MasterSite);
List<Item> test = item.GetChildren();
Tried many other ways but still no luck.
In the Multi-Site Status Viewer this code is used to load top site:
Item siteItem = VideoOS.Platform.SDK.Environment.LoadSiteItem(uri, _credentialCache);
When I do this, I see this error in the MIP logs of event server:
Error BuildSiteInfo Unable to cast object of type ‘VideoOS.Event.Server.MIP.Environment.ESConfiguration’ to type ‘VideoOS.Platform.SDK.Platform.SDKConfiguration’.
The Event Server environment is very much single site oriented, there is no way to know the other sites in that environment.
There are two possibilities.
