How to get generic event datasources from configuration in service plugin?
I have some generic event datasource in XProtect (Options => Data Sources)
How can i get this datasources from configuration by sdk?
I need get name, ip and port, it’s possible?
The MIP SDK has no methods where you can ask for these generic event ports. You must tell the administrator of XProtect what must be setup.
It would be possible for the administrator on an XPortect Corporate or Expert to add the information to Registrated Services from where you will be able to read it, I am not sure if this is beneficial as a workaround..
