How to import cameras offline via PS tools
Can I add a cameras offline via powershell? Now I can add/rename cameras when that are online, but I need import the cameras in lab before the system is from the client.
Denis
No, it is impossible. It is not possible when using the Management Client, nor using the MIP SDK, nor using the PS Tools.
Cameras need to be online when you add them.
I also found a similar question on Support Community. It says, “No, this is not possible, because devices need to be verified in regards to features, channels, and licensing when adding them. In theory, you could add a number of (virtual or physical) devices similar to the ones that will be on-site, and later use the Replace hardware feature with the actual devices, but there’s always the chance that they have too many differences and will cause problems matching features, channels or licenses.” https://supportcommunity.milestonesys.com/s/question/0D53X00007cDswLSAS/add-offline-hardware?language=da
Milestone Custom Development are working on a solution where you can add cameras before they are online, if you are interested, please ask your local sales representative for a quote and additional information.
ok, I’m asking to my local sales representative. Thanks
