How to integrate RFID tag into management?I couldn't find any article regarding RFID here, could you please give me a hint?Thanks
It is our wild guess but Sensor Monitor sample might be helpful for you –
https://doc.developer.milestonesys.com/html/index.html?base=samples/sensormonitor_sample.html&tree=tree_search.html?search=sensor+monitor
If this comment does not answer the question for you, please explain the integration scenario better. What should the integration do? What is the RFID usage you have envisioned? How should it look and act from a user’s perspective?
