I’m developing an integration of a custon AVL app with XProtect Corporate. I’ve been looking at the saple provided in other posts (ComponentSamples/ConfigAccessViaSDK) and successfully created the event/rule set in Management Client.
The question is if there is a more accurate way of getting the FQID of the newly created event other than traversing recursively the entire items tree?
You can ask for them in several ways:
Configuration.Instance.GetItemsByKind(Kind.TriggerEvent, ItemHierarchy.SystemDefined)
- This give a top node, where you need to perform a GetChildren call as long as the item has FolderType!=FolderType.No
or
Configuration.Instance.GetItemsBySearch(Kind.TriggerEvent.ToString(), … )
Here you retrieve a flat list - but it includes folders as well that you need to weed out.
Thank you Anders, it worked perfect using this method:
