Hi Guys!!
I’m creating a C# Solution using the information retreived from Milestone and use it to access thir party API : EdgeVis
The idea is to link a Milestone Device (encoder) with the EdgeVis Encoder. The first idea is to use the name of the encoders but wondering if there is another way , using for example and ID or value i can use from Milestone side.
Thanks for any comment.
I will suggest using the MAC address of the encoder for the mapping. You can get the MAC address through the Configuration API. Since you are in C# the easiest is to use this class (it’s in the properties collection):
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_configuration_items_1_1_hardware.html&tree=tree_search.html?search=configurationitems
How to get the MAC address from the EdgeVis device itself I don’t know.
Best regards,
Peter
