How to perform a silent install of Mobile Server supplying a BasicUser for VMS communication.
I am attempting to perform a silent install of the Mobile Server (2023 R2) and have a Basic User set up that is part of a Role that has Connect, Read, and Edit permissions for the Management Server.
I have attempted to install the Mobile Server using the following command:
C:\Users\Public\Desktop\Milestone XProtect Mobile Server 2023 R2 Installer.exe --quiet --parameters="MANAGEMENTSERVERURI:[http://xprotect-mgmt.larsenwh.com/]:MOSVMSUSEBASICUSER:true:MOSVMSUSER:XProtectMobileUser:MOSVMSPASSWORD:Milestone1234!"
I have also tried using the hashed/encrypted string for the password that is output in the installer log when I installed manually.
Here is the error from the installer.log file:
1/23/2024 12:15:37 AM	Error	An error occurred: 'FaultException`1: VMO61008: You do not have sufficient permissions to complete the operation.'. Error details:
Server stack trace:
   at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
   at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
   at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
   at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
   at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
   at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
   at VideoOS.WebService.Common.ServerCommandService.IServerCommandService.Login(Guid instanceId, String currentToken)
   at VideoOS.WebService.Common.ServerCommandService.ServerCommandServiceClient.Login(Guid instanceId, String currentToken)
   at VideoOS.WebService.Common.ServerCommandService.ServerCommandServiceProxy.<>c__DisplayClass21_0.<VideoOS.WebService.Common.ServerCommandService.IServerCommandServiceProxy.Login>b__0(IServerCommandService c)
   at VideoOS.WebService.Common.Framework.ManagerBase`2.CallWithRetry[TResult](Func`2 call, Func`2 manualErrorHandler)
   at VideoOS.Installer.Common.Utilities.ServerHelper.TryLoginToCorporate(Uri managementServerAddress, Uri identityServerAddress, ICredentials credentials)
I have also attached the entire installer.log file.
I also performed a manual (non-quiet) installation directly after my attempts at performing a quiet install, and the installer completed successfully.
How can I provide a password to the installer in quiet mode?
I totally agree with what Rie wrote - it’s better to ask in the support community.
From a developer perspective this seems correct.
I just gave it a try and Mobile server ended up working fine
"Milestone XProtect Mobile Server 2023 R3 Installer.exe" --quiet --parameters="MANAGEMENTSERVERURI:[https://bgvm-nid-07.ta.rd.local/]:MOSVMSUSEBASICUSER:true:MOSVMSUSER:basicusr:MOSVMSPASSWORD:M1le$t0n3M0b1l3"
