To use the demo of videopushsimple to push video stream to the terminal, the terminal needs a hardware device license. However, when adding hardware to the recording server in the management client, the terminal’s IP address is entered to connect. The connection fails, and the driver is not supported. Is there any other way to register mobile phone?
In order to be able to video push (no matter using a mobile device or one of the samples) you need to setup the system first. You can follow the steps described here:
KR,
Svetlana
