You can use
EventHandler VideoOS.Platform.Client.ImageViewerWpfControl.LiveStreamInformationReceived = delegate { }
Register on this event to be called when the live stream XML information is available.
You can use
Thank you Bo Ellegard Andersen
Can you help me with any sample
See the Video Preview plugin sample. https://doc.developer.milestonesys.com/html/index.html?base=samples/videopreview_sample.html&tree=tree_1.html
This is using ImageViewerControl -
ImageViewerControl.LiveStreamInformationEvent and ImageViewerWpfControl.LiveStreamInformationReceived are very similar and you should choose based on which ImageViewerControl class you use.
