How to send DriverCommand messages to a camera with HTTPS?
Like this example:
public void SendJSON(string jsonBody, string jsonCommand)
// object reg = EnvironmentManager.Instance.RegisterReceiver(JSONResponse,
// new MessageIdFilter(MessageId.Control.DriverResponse));
EnvironmentManager.Instance.SendMessage(
new VideoOS.Platform.Messaging.Message(
MessageId.Control.DriverCommand,
new DriverCommandData()
Command = jsonCommand,
Parameter = jsonBody,
SyncObject = currentCameraItem
this.currentCameraItem.FQID);
This works when the camera allows HTTP, but when I only allow HTTPS I get “ERROR: Empty response from device” from the camera.
I think the driver command should work the same way regardsless if the camera works on HTPP or HTTPS. I will open a support case on this.
What was the driver you were testing with? Camera model?
