We are currently encountering the following scenario during development:
- The camera is configured to use H.264 encoding
- The resolution is set to 6912 x 2624
- Under this configuration, the camera stream fails to display correctly
While searching for a solution, I found a related discussion on the Milestone Developer Forum: GPU Questions - Milestone Developer Forum
Based on that post, I added the following line of code before calling
BitmapLiveSource Init
EnvironmentManager.Instance.EnvironmentOptions[EnvironmentOptions.HardwareDecodingMode] = “off”;
After doing this, the camera stream was able to display successfully.
When adding two ViewItems, I ran into a limitation:
The setting `EnvironmentManager.Instance.EnvironmentOptions[EnvironmentOptions.HardwareDecodingMode]` appears to be global. I am unable to assign different decoding modes for individual ViewItems
For example, I would like to:
- Use HardwareDecodingMode = off for ViewItem A
- Use HardwareDecodingMode = auto for ViewItem B
But this does not seem possible with the current API.
Is there a way to configure HardwareDecodingMode per ViewItem, rather than globally?
If this is not currently supported, are there any alternative approaches or planned features that could help address this use case?
