Sirs, we have developed a plugin for Access Control. How can we test it?
Using a Milestone Corporate trial license, we can see the plugin running in the log and some output of it.
Attached some screenshoots. After restarting Milestone Event Server seems to run fine, but we cannot test the functionality.
Is there any Access Control trial license?
Do we need to make some license for our plugin? How?
Noted thanks, Eduardo
The screen shows that you have trial license until April 24th, though the ‘grace’ counter should have been one = the one door you have enabled.
I have tried to add the ‘MiniSystem’ test access control plugin - and it shows ‘Expire in 30 days’.
My best guess is that you have already used the grace period.
I suggest you try to activate with your current license, and if it does not have the licenses you need, contact partner@milestonesys.com with information on what you need, and they will enable the licenses you need - there is no fee. Remember to include the SLC code (file name).
